7 members (FAST55, Otto Skorzeny, dt235sd, FishinToms53, 3B, Rusty Heaps, 1 invisible), 95 guests, and 2 robots.
Topics128,115
Posts1,056,632
Members48,450
#359708 01/12/2008 3:49 AM
i am trying to figure out were does the hot wire come from and where does it feed into the fuse box any gmc electrical experts?
1949 SUBURBAN
If you are talking about the little original 2-fuse box under the hood, it feeds from the little circuit breaker on the headlight switch. One fuse is for the tail lights and the other is for the brake lights.
Paint & Body Shop moderator
4onthefloor you are talking about chevys fuse box gmc are different
1949 SUBURBAN
According to the wiring diagram linked to in your other post about this, it connects as 4onthefloor states.
I think the 2 fuse block you mention is from 51 and later.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
