| | | Forums66 Topics128,185 Posts1,057,207 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 493 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 493 | It turns out the 79 firebird rear end I have is 2.41. The t5 has 3.97 1st, 2.34 2nd, 1.48 3rd, 1.10 4th, .72 5th. From what I can tell it should take forever to get off ot the line but should top out at the speed of light. All of this is behind a stock 235 so maybe just short of the speed of light. 90% of of my driving is at 55 mph on a straight flat road. I am hauling light loads of lumber every now and then. About 6 times a year I drive 200 miles on interstate at 70 mph. I think I would be better off with at least a 2.73. Gas mileage is a high priority, I am looking for an old man driver not a race truck. Should I Bother with the 2.41 or is it not going to be as bad as I think.
Thanks Neilroy
| | | | | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | Over gearing can kill milage as it will use too much throttle to maintain speed...look for a diff in the 355 ot 370 range...doc | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | doc41 has the right idea those 2.41s are too high 3.00 to 3.55 with a 28" tire would be great 3.73 if you have taller tires. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | This site will help with gear ratios and speeds: http://www.onlineconversion.com/bigger_tires.htmWhat is your tire overall diameter? My guess is that you could not pull the 2.41 rear and an OD with the 235 unless a strong tail wind with a good down hill. 2.41 could be about right if you had the SM420 4 speed, then you have a low gear to start with, and the 2.41 is effectively an overdrive once you get to 4th. Grigg | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | I tried to run a IROC-Z 3.08 with a .72 T5 in my 235.....worked great as a 4 speed but wouldn't pull in 5th gear. I switched to an 88 Camaro 3.42 (62" wide) from behind a 2.8L V6 with a 28" tall tire and I cruise effortlessly at 70 mph in 5th@2000 rpms and still has plenty left. Can drop down to 45 mph in 5th gear and accelerate with traffic without needing a downshift. If I need to pull a trailer I can run at 65 mph in 4th gear at 2600 rpms. If most of your driving is at 55 mph a 3.55 or a 3.73 would also be good options.
Dave
| | | | | Joined: Jan 2008 Posts: 493 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 493 | Using the tire diameter calculator at angelfire.com looks like 205/75/15 which would be close to stock works out to 27.1". I will assume that it would be cheaper to find a new rear end than to swap out the gears. It looks like 3.42 to 3.73.
thanks neil | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Swapping for a 3.42 or 3/73 would be cheaper for the diff. However, the third generation Camaros/Firebirds (62") are 5 bolt and you may/will be faced with buying rims. I scouted the yards for some used 15" rims with 4" backspacing and found they are few and far between let alone finding 4 matching rims.
Secondly, the Camaro diffs have 2-5/8" axle tubes, not the standard 3" so you have to add some straps if you want to use the 3" U-bolts. The U-bolts/perches are available from the trailer section at most Tractor Supply stores. The up side is that they are plentiful in the 3.42's behind the 2.8 V6's.....I couldn't find a 3.73.
I'm running 255/70/15's on the rear and 235/70/15's on the front with 15X8 and 15X7 rims respectively, and have no clearance issues with a 5 bolt front disc conversion.
I really love my gearing setup as most of my driving is on the open road at 4 lane speeds. However, it was by no means cheap when you consider you're going to be springing for 4 new rims. Just thought you should be advised of some of the issues involved with using the Camaro/Firebird diffs.
Dave
| | | | | Joined: Jan 2008 Posts: 493 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 493 | I feel better now. 65 degrees, not a cloud in sight in East Mississippi. Dropped the top on the 1960 mga and drove around in the country, contemplating my rear end. I guess maybe I should say the truck's rear end. I am not sure which I will be concerned about if my wife gets wind that I am about to spend more money. I measure 61" mounting surface to mounting surface on that 1979 firebird. It looks like that year they also had a 3.23 and 3.42. it has a 5 bolt 4.75 bolt pattern. Will that extra inch make the rim quest any easier? Maybe I should have kept the 15" GTO rims that were on it. I didn't think they were good for the truck. I sold them and that leaves me $75 in the hole on the rear end.
| | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Going with the Camaro/Firebird 2nd or 3rd generation diffs, along with the 5 lug disc conversion on the front, saves you from having to spring for the $100+ special vendor roller bearing sets for the front and lets you use a wheel bearing/rotor/hub that's readily available from your local parts house, but you wind up needing the 4" backspacing.
I liked the idea of getting a diff which was readily available, with lower mileage, and being able to get replacement parts locally, without having to wait along the side of the road for a 5-7 working day delivery from UPS.
In your case you might be better off to scout up an open drive diff from a later model pickup and be able to use some available 6 lug rims. Some of the other guys who have done this swap might be able to offer some better suggestions. My experience is limited to what I had to do on my 54 to get her operational.
Dave
| | | | | Joined: Dec 2004 Posts: 128 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 128 | Well if your really after gas mileage - once you put a bit more gear in - say 3.08/3.23 the biggest jump will be to convert to TBI.
If your running the OEM carb your can expect 15% increase in mileage by converting to TBI. 90% of the needed parts are readably available in the wreckers. | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Should I Bother with the 2.41 or is it not going to be as bad as I think.
Thanks Neilroy I think worse. You'll stall at every stoplight and you'll kill the 235 if you're loading it.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Jan 2008 Posts: 493 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 493 | Found a 3.42 rear end from a 78 firebird that is 61" wide and life looks better. the TBI conversion is on the menu. Thanks for all of the info guys. | | |
