4 members (Gdads51, BillyDon, carbking, Paul Mullen), 130 guests, and 3 robots.
Topics128,272
Posts1,058,316
Members48,485
#360144 01/13/2008 6:42 AM
Q
Apprentice
Apprentice
Q Offline
Is the harmonic dampner on 235 special for this motor? or will a dampner for a small block work ? I have one but its in pretty bad shape and am not sure that its going to work like it supposed to .
quick54 #360156 01/13/2008 8:14 AM
quick54 i would suggest that you use the proper dampner for the engine they are desined for that particular engine a small block may not fit proprerly and could be a hazard to your engines berings
Mojave is correct. There is a difference between the dampner on a v8 & inline 6. Stick to the correct one or "bad vibes" will consume your motor.
beltfed #613658 01/26/2010 8:52 AM
call dampner dudes in los angeles they can repair any harmonic balancer
