0 members (),
156
Mod | | | Forums66 Topics128,271 Posts1,058,314 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 23 Apprentice | | Apprentice Joined: Aug 2007 Posts: 23 | Is the harmonic dampner on 235 special for this motor? or will a dampner for a small block work ? I have one but its in pretty bad shape and am not sure that its going to work like it supposed to . | | | | | Joined: Jan 2007 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 44 | quick54 i would suggest that you use the proper dampner for the engine they are desined for that particular engine a small block may not fit proprerly and could be a hazard to your engines berings
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Mojave is correct. There is a difference between the dampner on a v8 & inline 6. Stick to the correct one or "bad vibes" will consume your motor.
| | | | | Joined: Jan 2007 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 44 | call dampner dudes in los angeles they can repair any harmonic balancer
