2 members (rick46ia, NJC),
112
Mod | | | Forums66 Topics128,260 Posts1,058,343 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2000 Posts: 116 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 116 | I tried the search engine, but it brought up a lot of extraneous posts; so I'll ask this question which has probably been asked many times before:
What have you guys found to be the most effective and efficient method of bench bleeding your master cylinder?
Thanks in advance for yours thoughts.
Jim | | | | | Joined: Jan 2007 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 79 |
1949 "Heinz 57"
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | [quote=jmmmn37]
"What have you guys found to be the most effective and efficient method of bench bleeding your master cylinder?"
If you can determine that your MC is level, bleed it on the frame. I don't care what others say, it won't be any more level on a bench or on a vice. I have never bled a MC on a bench and never had an air bubble in the system.
~Jim
