1 members (delky),
65
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | I have done a search for this, maybe not far enough back, but I searched pretty thorough.
The gauge will only read from EMPTY to HALF-FULL. I took the sender out, applied power and grounded it. I then would move the float arm back and for the whole range. The gauge would read the whole range from EMPTY to FULL. I would then re-install the sender and it would only read up to half. I just filled up today! The one thing I think it may be is the ground. When I re-installed it, it wasn't even grounded and it read HALF-FULL. I attached the ground wire and it changed nothing.
So what is the deal here? Do I have a ground problem? Because the gauge and sender work without the ground wire attached.
58' 3200 235 3-speed/OD
| | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | Have I stumped ya'll or what?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if it reads [wrong] when in place there's nothing wrong with the ground - if it reads [right] when moved manually, the float is being held in the wrong position - I'd bend the arm so that when the tank's full it reads full and see what it reads when the tank's empty
Bill | | | | | Joined: May 2007 Posts: 25 Apprentice | | Apprentice Joined: May 2007 Posts: 25 | ApacheFiend,
Cannot believe it, but I have the same issue. Rebuilt cluster, new sender they tell me was even calibrated - I only get to half full on a full tank of fuel. Maybe someone knows!
1950 AD Chevy 235 - 3 on the tree - straight pipe & cherry bomb - baaaam bam bam bam bam I am no mechanic, but I am going to try on this one!
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | actually mambo, it's a real common issue - so the next check is as soon as the gauge reads Empty, stop and fill it to see how much it takes to refill ... I'm bettin it'll be about 8-10 gallons
then do as I suggested above and with a full tank, bend the float arm until it reads a full tank when in place
Bill | | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | Red58-
You know when my tank reads Empty, it does only take about 8-11 gallons or so. Im gonna double check it on this fill up and I will try bending to correct the issue. Thanks alot Red!
| | | | | Joined: May 2007 Posts: 25 Apprentice | | Apprentice Joined: May 2007 Posts: 25 | Red, been gone awhile :-(
I cannot get the thing to measure full even by hand. I have a ground wire on the sender, I pull it out, push it all the way up, still at half - or just above. I was told from BowTiebits that the gauge was calibrate and it is hard to believe that I have had this same issue with 2 different rebuild gauges and two different senders. It really is not rocket science but it has me baffled.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | maybe the wire rubbed raw and 'grounding' between the sender and gauge? sender wrong resistance value?
Bill | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | This sounds to me like a problem with the guage, not the sender. The guage case itself needs to have a good ground to operate. Take a jumper wire with alligator clips and just clip between the guage case and a good ground and see if the needle will move to full when the sender is all the way up. If it does, either make a good mechanical ground to the dash, or just run a permanent ground jumper. Hope this helps. | | | | | Joined: Jul 2006 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 92 | I found out my sender was for a 54 not a 50. Works now  Virg | | | | | Joined: May 2007 Posts: 25 Apprentice | | Apprentice Joined: May 2007 Posts: 25 | Well, here is what I am going to do this weekend. I will run a ground wire to the gauge and a new one to the sender and a different wire from the gauge to the sender. The wires are new but in the painting of the truck something “could” have happened. I will post then. Thanks for the suggestions!
| | | | | Joined: May 2007 Posts: 25 Apprentice | | Apprentice Joined: May 2007 Posts: 25 | Well I guess I have learned to live with my gauge even though I don’t like it. I was told by bowtiebits that the sender and gauge were calibrated for each other. I ran new wires, I checked voltage, still full of fuel, gauge reads just above half. I am lost.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you might try bending the float arm, to fool it into thinkin it's full - when it is try the unit out of the tank [held against a ground] to see if the full range of the gauge reads ehile you manually move the float, if there's a position it reads full, bending it should work, then you just have to figure out what reading means empty .... carry a gas can until you run out Bill | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Sometimes you just give up! I would guess your at that point and don't blame you one bit. Remember there is always a silver lining in every cloud and we should always seek to see something positive in every event. It is a good think you can tell when you are about to run out of fuel. Now isn't that a positive thought?
~Jim
| | | | | Joined: Apr 2008 Posts: 143 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 143 | I had this same problem with my sending unit. Grounding it to the cab instead of the tank seemed to fix it. | | |
