1 members (Stovebolt48),
73
Mod | | | Forums66 Topics128,021 Posts1,055,352 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#35945 12/21/2004 12:05 PM | | Anonymous Unregistered | | Anonymous Unregistered | I'm hoping there's stovebolters from Florida out there. I just went to title my '52 panel. DMV used my engine serial number instead of the VIN for the title. They said any vehicle '55 & lower uses the engine serial on the title. Which means, if I change engines, I have to retitle! Have any of you heard of this? | | |
#35946 12/21/2004 1:58 PM | Joined: Jul 2000 Posts: 579 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 579 | When I registered BillyBob in 1996 in Palm Beach County, they used the door plate. Belts, Hoses, Tag & Title | | |
#35947 12/21/2004 6:02 PM | Joined: Jan 2004 Posts: 223 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 223 | Every state is different on title and VIN# requirements. My 1950 truck was originally titled in Washington state using a long gone engine number. Oregon didn't like this or the ID plate held on with screws. I too went armed to DMV with books showing that engine number was used and asked them to assign ID# from door plate. DMV didn't like this and they made me get appointment with state police to confirm the truck wasn't stolen and to try to find the a VIN number stamped on the frame. No amount of talking would change their mind that they would not find one. After about two hours of a state trooper wirebrushing my frame (nice fringe benefit) he gave up and sent me back to DMV with a note saying assign the vehicle ID # on door post as VIN#. (Just what I had asked them to do in the first place.) They again didn't like the screwed on door plate so they stamped an aluminum sticker with the ID# to put on the door post. This sticker was right below the ID plate with the same # and was stuck on a bad rattle can paint job. It was easier to remove then the plate when I started restoration. I am sure I will have to battle with DMV again when I go in to re-register my truck after restoration. Good luck, Steve O | | |
#35948 12/21/2004 7:00 PM | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Is this that truck from Cuba?
I thought they sunk it.
Dennis -there is nothing stronger than the heart of a volunteer-
#35949 12/21/2004 8:53 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by lindylou0905: Have any of you heard of this? My '54 came to me with a Texas title that used the engine number instead of the serial number. I first transferred the title to my name in Washington. Then went through our local inspection process to get the number changed to the one on the body. And then pulled the motor out and sold it. I expected lots of trouble, but it turned out to be pretty easy, just a string of hoops to get through.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#35950 12/22/2004 1:07 AM | Joined: Oct 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 112 | lindy well when I went to register the 40 burb I have I hadd dmv send a inspector out to look at the burb and give me a number sheet or form from him. checked with dmv first. also had the original registration from northern states to show number on plater on cowl. only problem I had was had to find guy I bought it from and get notary stamp bill of sale. Florida is getting like californis they makeit up as they go along. for that matter probably like the whole country. Everyday just seems a litle more weird. I would go back to dmv and ask for an inspector to check it out and justify the engine serial thing. Good Luck
jbennnet 40 burb | | |
#35951 12/22/2004 1:38 AM | Joined: Mar 2003 Posts: 313 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 313 | My 36 GMC used the Vehicle Ser # on the title. Had to have a notary verify the number when I transfered the AZ title to Fla. So I would say that whoever you talked didn't know thier [censored] from up | | |
#35952 12/22/2004 7:35 PM | Joined: Jan 2004 Posts: 223 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 223 | One of the greatest hassles with DMV can sometimes be handy. Don't like what the clerk told you? Get back in line and go to another clerk, you may get the answer you want! Steve O. | | |
#35953 12/26/2004 3:10 AM | Joined: Jan 2004 Posts: 58 Member | | Member Joined: Jan 2004 Posts: 58 | I registered my 1950 which I purchased from NC and they used the VIN number. | | |
#35954 12/26/2004 11:14 AM | Joined: Aug 2004 Posts: 399 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 399 | My 41 had a Florida title with the engine (sic) number. The german version of the DMV is verry picky on numbers but they don`t see this 41 Chevys to often So I made my own plate (with the engine number!) and put it on the door post with 2 rivets. The bought it  plus the new 1959 235 Without this trick I would never get it on the street. Happy hollidays to all, Frank | | |
