| | | Forums66 Topics128,068 Posts1,055,881 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 111 | 55 2nd 3/4 ton. I am changing third member on this truck, replacing 5.17 gears with a 69 automatic suburbans 4.11 gears. the new/used third member feels like it has a little more play in it, I have read the shop manual on how to adjust ring gear and pinion backlash but am looking for a better explenation of what it is I would be doing. I guess backlash adjustment for dummy's is what I need.
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Google is your friend. 58,000 + hits for "ring and pinion adjustment" ..... many with pictures. Good luck.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | DG,,,,On a used diff that has the wear patteran set leave it alone as you have the chance of the diff singing you to sleep..If it is very loose you have to do it set it .006 to .010,,and maintain bearing preload...doc | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy dgallagher and guys, adjusting the backlash on a used gear set can be a little tricky. The gears will have a wear pattern in them, under no circumstances do you want the gears to be contacting wear ridge to wear ridge which may be where they will be if you just re-adjust your backlash. Personally I would not install a used third member without dissassembling it and checking all the bearings and the pinion seal wearing surface, and installing new parts were required, hope that helps. | | |
