3 members (Bill Marlow, tclederman, 52Carl), 54 guests, and 3 robots.
Topics128,090
Posts1,056,028
Members48,432
55 2nd 3/4 ton. I am changing third member on this truck, replacing 5.17 gears with a 69 automatic suburbans 4.11 gears. the new/used third member feels like it has a little more play in it, I have read the shop manual on how to adjust ring gear and pinion backlash but am looking for a better explenation of what it is I would be doing. I guess backlash adjustment for dummy's is what I need.
Google is your friend. 58,000 + hits for "ring and pinion adjustment" ..... many with pictures. Good luck.
You Tube
DG,,,,On a used diff that has the wear patteran set leave it alone as you have the chance of the diff singing you to sleep..If it is very loose you have to do it set it .006 to .010,,and maintain bearing preload...doc
3B Offline
Hy dgallagher and guys, adjusting the backlash on a used gear set can be a little tricky. The gears will have a wear pattern in them, under no circumstances do you want the gears to be contacting wear ridge to wear ridge which may be where they will be if you just re-adjust your backlash. Personally I would not install a used third member without dissassembling it and checking all the bearings and the pinion seal wearing surface, and installing new parts were required, hope that helps.
