| | | Forums66 Topics128,186 Posts1,057,315 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 67 'Bolter | | 'Bolter Joined: May 2004 Posts: 67 | Does any one know what year model and ton truck rear axles will interchange with the 3800 Series? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | '47-'72 are essentially the same axle. Are you looking for a beeter gear using a new 3rd member, or are you in nead of an entire axle assembly? I'm not dure on widths or spring pad placements, but I would think pretty much any rear up to around an '87 would work without being to wide. An axle from a '73-'87 Duallie would be even better, as they are a bit narrower than the single wheel trucks. Be cautios with the '81-'87 3/4 tons, though, as some of them are the semi float 9 1/2" ring gear 14 bolt semi float. Not as strong as the 14 bolt 10 1/2" full floater found on 1 tons and heavy 3/4 tons. Some also come with Dana 70s, usually duallies or Camper Specials, and also tow trucks, but the tow truck version is even narrower than the regular duallie, so I'm not sue of fitment.
Bill Burmeister | | | | | Joined: May 2004 Posts: 67 'Bolter | | 'Bolter Joined: May 2004 Posts: 67 | | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Measure the width carefully, some of those axles will be much wider than the stock rear. Also check the studds against the wheels you want to run. Some of the later axles have much larger studds than the earlier ones, and if you want to run your original wheels you could have problems as a result.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
