7 members (jal12147, F100Ranger, NJC, Bruce 1954-4100, Bill Hanlon, Hotrod Lincoln, 1 invisible),
111
Mod | | | Forums66 Topics128,087 Posts1,056,338 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#35865 02/21/2002 8:50 AM | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Ok. We have a 1953 Chevy truck... I have guesstimated, that the motor is a 1957 235... based on assundry numbers here in the forums and elsewhere on the net... my pop wants to keep the floor, pedal starter action on the 53 truck/cab/chassis with the 57 235 motor. My question is, can this work? Will a 1953 starter bolt up in the same way on the 1957 235 block? etc.. advice... tips... a place to get a starter for this in the Atlanta, Georgia metro area... Thank you...  | | |
#35866 02/21/2002 10:10 AM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Yes, it will bolt up. NO, it will not mesh with later 12volt ring gear on flywheel. You need to get a gear drive from a 55 up 12volt starter to put on your 53. OR, why not a later starter? It will be 12volt if you are changing to it. You can run the 6-volt starter on 12 ok, I have been for 4 yrs on my 54, no problems. What starter did you have in it? Maybe you can just put the switch for push pedal on it and remove the selonoid? I thought all the starters up til 60 had the foot pedal anyway. Out of a car?
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
#35867 02/21/2002 3:38 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | If the motor and flywheel are '57 vintage then you need a 12 volt starter. Get a 12 volt starter for a '55-59 chevy pickup C-10 or Apache. The starter motor will be 12 volt, the pinion will be correct for the 168 tooth ring gear used '55-'62, and a '55-59 truck starter will be a foot-masher. The 53-62 235 car starters had electric solenoids.
hope this helps chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#35868 02/21/2002 4:34 PM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | (Woogeroo, Does your nickname have an Australian derivation?) 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#35869 02/21/2002 5:25 PM | Joined: Mar 2001 Posts: 279 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 279 | Now I have a question. I have a '61 235, but plan to use the flywheel from the '55 235 that was previously in my truck, since the '61 didn't come with a flywheel. Will this bolt up ok and can I use my 6 volt starter? I hadn't even thought about 6 volt vs. 12 volt. | | |
#35870 02/21/2002 7:11 PM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Chevrolet flywheels have the same bolt pattern from 1942-62. The difference is in the tooth count on the gear. (Also clutch size).
See the USA in your vintage Chevrolet! My Blog | | |
#35871 02/22/2002 1:56 AM | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Not to my knowledge. I am from Atlanta, GA... Originally posted by Wally / Montana: (Woogeroo, Does your nickname have an Australian derivation?) | | |
#35872 02/22/2002 1:59 AM | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | so, the 1955-57 235 inline sixes had 12 volt electrical systems? Therfore, a 12 volt starter, from a truck, with the masher unit on it, is required?
I just want to make sure I am getting this right...
thank you peepers...
that's slang for people...
heh...
-W | | |
#35873 02/22/2002 2:05 AM | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Someone asked if it(the starter) was out of a car...
there was a starter in a box in the truck cab... but we have been told it is for a Chrysler/Dodge or something... dunno...
anyhoo... gearhead here in the group told me the numbers on the block match up with it being a 235 1957 block from a car... this block/engine was in it when we bought it...
I have all the casting numbers for the motor stuff on our website, if ya care to read it...
the url is in the signature of some other messages...
thanks for the help folks...
-W | | |
#35874 02/22/2002 4:15 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | You can run the 6 volt starter on 12 volts. Just don't crank for more than 15 or so seconds at a time, or the starter will get hot. These old starters will take it, there are a lot of us doing it.
Fred 52 3600 69 C-10
#35875 02/22/2002 6:52 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | All 235s from 1955 to 1962 (last year) had 12 volt electrical systems & starters. The car engines had electric solenoids. Just turn the key and it starts.
The trucks up to '60 had foot-pedal starters. In '55 Chevy went to 12 volt for all their vehicles. They changed the # of teeth on the ring gear from 139 to 168 and also redesigned the starter pinion to match. They kept the foot pedal in the trucks. In 1960-61 chevy started to equip their trucks with electric solenoid starters just like the cars got in the early '50s.
Verify your 235 is a '57 model. I assume the flywheel is a '57, has 168 teeth and expects a 12 volt starter. So you'd need a 12 volt starter. The truck's ign switch should only have a "off" and "on" position, no "start" position. So you have to use a 12 volt foot masher unless you change the ignition switch and run the "start" wire to the starter solenoid.
So count the teeth on your ring gear to be sure. 168 teeth means you need a 12 volt starter. 139 teeth means you need a 6 volt starter.
If I may digress a little, I've been hearing that you can run a 6 volt starter on 12 volts. I would have to disagree. YRMV, but I tried running my '54 235 6 volt electric solenoid starter on 12 volts for 2 years. I burned up brushes every 4 months, burned up the field windings, burned up a solenoid, ruined a pinion, and ate through TWO ring gears. And the motor didn't require a lot of cranking to start. After I went to a 1960 12 volt ring gear and starter, I haven't had any problems.
hope this rambling helps
chip
#35876 02/22/2002 11:58 PM | Joined: Nov 2000 Posts: 45 Member | | Member Joined: Nov 2000 Posts: 45 | First thing you need to find out is what you have for a flywheel as this will determine what to use for a starter. They could have used either one when they retrofitted the newer engine. As said allready, the 6 volt system has a different tooth count from the 12 volt, but both flywheels/starters can be used with your engine/tranny combo. There are numbers on the engine side of the flywheel that can also tell you what it is if you don't fell like counting teeth.
As said before, 55-59 or so trucks will have the push start 12 volt starter if you need one. Otherwise, the 6 volt one can be used on 12 volts. I had my '53 setup this way for years without problems. If you want to use a solinoid starter, changing the ignition switch isn't necessary. The factory did this as an option in both 6 and 12 volt versions and the wiring is shown in the factory shop manual. All you need is one of those cheap clamp-on horn buttons to do it. Turn key on, hit the button. My Dad's '49 car was that way from the factory. | | |
