| | | Forums66 Topics128,115 Posts1,056,594 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 91 | Can the dash, of my 49 1/2 ton, be removed? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, with a lot of drilling and cutting, they're spot welded in
Bill | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | The factory assembly manual shows all the attachment points and spotweld locations. Lot's of work! | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | 49 chevy man,
I have done this task! You will need two cabs. One cab is destroyed, saving the dash, while the other dash is destroyed saving the cab.
Stuart | | | | | Joined: Dec 2007 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 91 | Thanks for your input I have made up my mind not to remove the dash
Bennie | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | 49 chevy man,
Stuart Well put Stuart. Repop dashes are now available so you should be able to cut away the rot/damage and patch it using the replacement. Pricey at over $300.00 though.
1952 1300 Canadian 1/2 ton restomod You Tube | | |
