9 members (WICruiser, Ponchogl, GMCJammer51, Otto Skorzeny, Wayne67vert, Gray_Ghost, dt235sd, 78buckshot, TUTS 59), 135 guests, and 1 robot.
Topics128,105
Posts1,056,545
Members48,448
#358260 01/09/2008 2:38 AM
Can the dash, of my 49 1/2 ton, be removed?
yes, with a lot of drilling and cutting, they're spot welded in
The factory assembly manual shows all the attachment points and spotweld locations. Lot's of work!
49 chevy man,
I have done this task! You will need two cabs. One cab is destroyed, saving the dash, while the other dash is destroyed saving the cab.
Stuart
Thanks for your input I have made up my mind not to remove the dash
Bennie
Originally Posted by atomarc
49 chevy man,
Stuart
Well put Stuart. Repop dashes are now available so you should be able to cut away the rot/damage and patch it using the replacement. Pricey at over $300.00 though.
You Tube
