| | | Forums66 Topics128,077 Posts1,055,932 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#35796 05/23/2005 4:55 PM | Joined: Jun 2003 Posts: 156 Shop Shark | | Shop Shark Joined: Jun 2003 Posts: 156 | I have a 59 3200...noticed a wheel bearing seal leaking and thought I would pull the axels and put new seals, bearing etc...Pulled the cover off the differential and its quite a mess in there..needs new bearings, side gears, spider gears, and the pinion had gotten into the carrier housing pretty good..to the point of making it hard to get the spider shaft out...also where the spider and side gears run is pretty scored up..even the axels are worn where the bearings ride..Would like to hear some opions on whether I need to try and find a whole rear with housing and rebuild it or try to fix what I got...
"All right, they're on our left, they're on our right, they're in front of us, they're behind us...they can't get away this time"
Lt Gen. Lewis B."Chesty" Puller, USMC | | |
#35797 05/23/2005 10:16 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I think that has a drop out center section. You can remove the pumkin & replace it with a good used one or overhaul it first. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#35798 05/23/2005 10:37 PM | Joined: Aug 2004 Posts: 141 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 141 | Hi, I, too have a '59 Chevy 3200 series pickup and have been through the wringer RE: rear axles. I went through the whole deal and brought it 'up to snuff' but I'm still wanting a posi unit. Yeah, I know posi's were offered back then, but just try and find one. A mid/late 70s Chevy rear axle will bolt up, just check the spring-pad spacing. NAPA has all manner of 'two-size' U-joints to mate an axle to a differential. I've seen these later rear-end units complete with posi, although they usually have pretty high-geared ratios (like around 3.08 or so). Later on, the spring-pad spacing got greater, thus requiring welding on new spring-pads, although that's not such a big deal. Regards, Apache Kid | | |
#35799 05/24/2005 10:38 PM | Joined: Jun 2003 Posts: 156 Shop Shark | | Shop Shark Joined: Jun 2003 Posts: 156 | Thanks for the replies,Wrenchbender & Apache Kid...I'm trying to find a good carrier to rebuild..
