1 members (chemanic), 87 guests, and 2 robots.
Topics128,134
Posts1,056,416
Members48,441
#356687 01/05/2008 1:08 PM
Clifford 4-barrel manifold with water heat.
If the hoses running to the manifold are in line with the heater, how does that heat the manifold if the water is not circulating through the heater? The way I understand it the installation involves cutting one heater hose and putting the manifold in between the cuts, in line with the heater. I know that's an over-simplified explanation.
Or am I thinking wrong here?
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
ODSS President
ODSS President
You're OK, but the heater doesn't HEAT the water it's just a vehicle for the heat via the heater core which is a mini radiator which radiates heat into the cab. You adjust the heat via a cable which limits or shuts off the hot water coming from the heated water in the engines internal water jackets. You'll get your heat... oh wait a minute.. I think I know what you're talking about....what if you DON'T HAVE THE HEATER ON... IS THE WATER STILL GOING TO CIRCULATE?
I think most people run a separate heating loop which is what I have planned for my Edelbrock conversion.
~ Cosmo
1949 Chevy Half Ton
The heater doesn't heat the water? That's stupid... when did they change that... how an I supposed to make tea and Ramen noodles with cold water? ohwell
grin
Woody
Door Art Collection
It depends on which heater you have. The deluxe heater has a flow control valve which would limit the amount of water heat into the intake. The non-recirc heater does not come with a valve.
However, you are likely to have the cabin heat on when you need manifold heat anyway, so its not too likely to be a problem.
Paint & Body Shop moderator
Thanks everyone. I'm getting a thing that adds a hose fitting and I'll simply add a T to the return line so that water circulates continuously.
Thanks to everyone for clearing this up for me.
Woody
Door Art Collection
ODSS President
ODSS President
Fantastic water heated plumbing is shown here. This is one of the cleaner applications I have seen.
I actually went w/o a heated manifold for about a month and a half this past summer and the truck performed poorly. I made my own bottom plate similar to this. Here's water heated loop terminus.
~ Cosmo
1949 Chevy Half Ton
I don't want to hi-jack this thread "but", I have a question.
Who supplies the double t clamp shown in cosmos picture.I'm referring to the clamp holding the two water lines apart.I can find the plastic ones,but no luck finding the metal ones.
Thanks !!!!!!!!!!!
1951 3100 Chevrolet
Thanks for the compliment on my system Cosmo! The idea actually came from 4onthefloor(thanks again). You don't need the "T" if you utilize a bypass thermo housing and a waterpump from a 261 as 4onthefloor suggested. The waterpump that NAPA sells for the 235 is the same as the original 261 pumps. They have the dual fitting holes and will work. The thermo housing from a 261 may take some time to find. An option to that is the fitting plate that Tom Langdon sells that goes between the therm-housing and the head. It is good because the fitting comes out on the drivers side so the tube bending will be cleaner and easier. The heatplate started out as a 4"X5" piece of 5/16" flatbar. I cut it to size with a hacksaw, then shaped it with a grinding wheel. The lines are cheap brake lines from NAPA. The fittings took a while to gather and get right, but then all you need is a cheap tubing bender and a flaring kit and your off to the races. It helps to have a neighbor with a machine shop who can drill and tap the inlet/outlet holes in the plate! The moral of the story is you don't have to be a mechanic to do it.
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
Bow Tie - Go to summitracing.com & do a search for line clamps.
Doug
''' I'm referring to the clamp holding the two water lines apart. '''
that's a common hot rod fuel ''bullet type'' clamp
search any or go to a rod shop. they are available in many and different sizes, same-same, or large/small
Jim & Caroline
desertdog and carolines truck, I was talking about the clamps holding the water line apart.I can find the plastic ones in the right size.I can't find the metal ones in the right size.I checked summit,they don't have them in the sizes i need.
I'll do some more checking,thanks !!!!!!!!!
1951 3100 Chevrolet
that IS what I/we am/are referring to
they are made for fuel lines mostly. i'll do the work for ya
summit
>> http://store.summitracing.com/partdetail.asp?autofilter=1&part=BSP%2D68220&N=700+115&autoview=sku
>> http://www.lsbilletworks.com/clamps.html
http://www.jegs.com/webapp/wcs/stores/servlet/product_10001_10002_150902_-1
http://www.davesmotors.com/store/product1555.html
Jim & Caroline
