| | | Forums66 Topics128,020 Posts1,055,345 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | I have 2 matching Carter WA-1 single barrel carbs. They both have the number 146-72 stamped on them. The holes in the base on both carbs have been elongated so they will fit an intake with 2 5/8" or 2 15/16" between the carb mounting bolts. (center to center). Can anyone tell me what motors these carbs were used on? Thanks much! | | |
