0 members (),
139
Mod | | | Forums66 Topics128,167 Posts1,057,021 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Does anyone know if a 46 COE steering wheel would fit a '40 Chev 1/2 ton? I like the looks of the beefier wheel but not sure if I would run into problems.
40 Chevy 1/2 ton
| | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | The 46 COE has a larger diameter steering shaft. The COE steering wheel will not fit a half ton without modification. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | The wheel in my 47.1 gmc coe is far bigger/thicker then the wheel in my chevy 41' 1 1/2 ton | | |
