2 members (rick46ia, Hotrod Lincoln), 72 guests, and 4 robots.
Topics128,022
Posts1,055,352
Members48,420
#356915 01/05/2008 10:53 PM
U
U Offline
The book say to set the timing so that the pointer is on the ball; is this correct? On my newly rebuilt engine I'm getting a lot of popping in the muffler, especially when cold. I've changed three carburetors but it doesn't seem to change this. What could it be? Are my valve springs weak, or is the timing off. I set the valves to .006 and .20 like it says.
uncleb #356923 01/05/2008 11:30 PM
You could try to advance the timing a bit. I like to use a vacuum gauge and set the dist at peak vacuum. Also the vacuun gauge is a great diagnostic tool, for checking valve adjust etc.
Best of luck
Jim
Turlock
P.S. Love the suburban, had the pickup to match but sold it like a fool.
1946 1/2-Ton Chevy
U
U Offline
Yeah Jim, I know the feeling, but someing else always comes along. I'll try the vacuum gauge but still wondering why the missing and poping in the muffler. Runs fine out on the road.
ron brazell
vallejo ca
uncleb #356936 01/05/2008 11:59 PM
An old friend of mine showed me a trick, with the car running hold a piece of paper up to the exhaust pipe as a quick check for a miss.
You still could need to re-adjust the valves or have a vacuum leak, carb problem etc. Also a compression test is an important first step of a good tune up.
Be sure your valve adjust is with the motor fully warmed up, like 20 minutes.
1946 1/2-Ton Chevy
uncleb #356939 01/06/2008 12:08 AM
What year 261?
What year flywheel do you have on your engine?
What year clutch housing do you have on your engine?
Have you checked the float carburetor setting?
U
U Offline
I'll try changing the distributor tomorrow and see if that changes anything.
uncleb #356946 01/06/2008 12:21 AM
uncleb,
If you get a vacuum gauge for diagnostics, set the carb with the vacuum gauge (maximum vacuum at the idle setting) and set the timing with the vacuum gauge (rotate distributor for maximum vacuum). It's worth a try.
Good luck,
Tim
tclederman #357098 01/06/2008 5:29 AM
Mine did that when I forgot to put gaskets between the spacer and the carb/intake.
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
bigmacdaddy #357154 01/06/2008 10:32 AM
Are you using the 261's flywheel or the original 216 flywheel? The balls aren't in the same spot between the two. Popping can also be a sign of poor dwell, check the point gap or measure the dwell with a meter.
Paint & Body Shop moderator
4ontheFloor #357228 01/06/2008 4:26 PM
U
U Offline
Hmmmmmmm....., now I don't know if I did use the 261 flywheel, I'll do some comparing, excellent point.
uncleb #357237 01/06/2008 4:43 PM
As also asked earlier, what clutch housing (bell housing) are you using? Is it possible (4ontheFloor, others?) that the pointer might be located differently on certain truck/auto early/late 216/235/261 clutch housings)?
If you set the timing with a vacuum gauge, the location of the ball, pointer, and type-of-marking on flywheel will not matter. I prefer a timing light but the vacuum method also seems to work OK.
Tim
tclederman #357378 01/07/2008 1:46 AM
U
U Offline
Good advice, I'll use the vacuum gauge, then mark the flywheel. Thanks Tim.
uncleb #357387 01/07/2008 2:03 AM
Dave Giorgi
Unregistered
Dave Giorgi
Unregistered
As JIMERIT said..." the first and most important step of a tune up is to check the compression". Start there that way yo'll know if its a valve problem.
Dave
