10 members (Shade Baby, klhansen, cmayna, Rusty Rod, David Bush, greenie-reddy, Cosmo, Lightholder's Dad, Peggy M, 1 invisible), 58 guests, and 2 robots.
Topics128,074
Posts1,055,913
Members48,429
#356919 01/05/2008 11:09 PM
Today I found a 250 L6, (no way it could be a 292,) with what
appears to be a progressive 2 barrel that sits 90 degrees to the
crankshaft axis and split exhaust!
The whole package appears to be factory, right down to the air cleaner!
The exhaust is a front3 / back 3 setup with rough casting marks
showing. The head and intake are one piece.
The owner saved it out of a wrecked 1979 C-10 in 1983. It has been
in dry storage and is not stuck. He says it is just the way he got it.
I would really like to know more about this engine. Does anyone
recognize it from my poor description?
Roadmarks #356927 01/05/2008 11:39 PM
They called them a integral head if I remember correct. My Dad had a couple of them for work trucks and what I remember is they worked ok. We put dual exhaust on one of them, sounded good but didn't change performance or economy at all. I remember putting a head gasket in a few integral head motors years ago. Lots of vacuum hoses and emissions stuff on them.
don stocker #356930 01/05/2008 11:45 PM
CJL Offline
I'd be interested to see pictures of this engine if you care to post some.
CJL #357070 01/06/2008 4:23 AM
i've seen several of them. it may be best to steer clear unless you want just the lower end. you can always change them out.
hoggyrubber #357104 01/06/2008 5:40 AM
I had a 79 GMC Van with this setup. Ditto to comment on lots of emissions crap. I had some carb trouble and some burnt valves, so I put an earlier head and it ran pretty good.
