1 members (Hotrod Lincoln),
130
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#35681 01/15/2002 3:56 AM | Joined: Dec 2001 Posts: 11 New Guy | | New Guy Joined: Dec 2001 Posts: 11 | I am tired of my truck "wandering" with my reversed 7 in. rims on the front. Stock axle, one leaf removed. So, I now have a pair of stock 15 in. wheels, zero offset. I am wondering what radial tire to mount? The stock wheel width is only 5 1/2 inches. I have reversed 7 in. on the back, which is fine. Size of existing front tires: 215/70 15. Any suggestions? Should I have new outer rims added to the centers, stay with the zero offset only go 6 in. or 6 1/2 inches??
1950 Chev 3100 Nevada City, CA
#35682 01/17/2002 7:55 AM | Joined: Sep 2001 Posts: 272 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 272 | on my 56 I am running 6 1/2" rims and 235-75-15 with no wandering problems. Check the air pressure 3-5 pounds less in the back will cause wandering too, reguardless of tire size. Brad | | |
#35683 01/17/2002 8:20 AM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | I got 700R15 that go good on a standard 5 1/2 " rim . I keep the pressure up . Wouldn't hurt to check the castor and toe in/out while you're at it . | | |
