4 members (delwrench, Southerntruck, cmayna, dt235sd), 123 guests, and 3 robots.
Topics128,142
Posts1,056,490
Members48,442
I am tired of my truck "wandering" with my reversed 7 in. rims on the front. Stock axle, one leaf removed. So, I now have a pair of stock 15 in. wheels, zero offset. I am wondering what radial tire to mount? The stock wheel width is only 5 1/2 inches. I have reversed 7 in. on the back, which is fine. Size of existing front tires: 215/70 15. Any suggestions? Should I have new outer rims added to the centers, stay with the zero offset only go 6 in. or 6 1/2 inches??
1950 Chev 3100
Nevada City, CA
on my 56 I am running 6 1/2" rims and 235-75-15 with no wandering problems.
Check the air pressure 3-5 pounds less in the back will cause wandering too, reguardless of tire size.
Brad
I got 700R15 that go good on a standard 5 1/2 " rim . I keep the pressure up .
Wouldn't hurt to check the castor and toe in/out while you're at it .
