| | | Forums66 Topics128,071 Posts1,055,901 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Clifford 4-barrel manifold with water heat.
If the hoses running to the manifold are in line with the heater, how does that heat the manifold if the water is not circulating through the heater? The way I understand it the installation involves cutting one heater hose and putting the manifold in between the cuts, in line with the heater. I know that's an over-simplified explanation.
Or am I thinking wrong here? | | | | | Joined: Jan 2001 Posts: 1,422 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,422 | You're OK, but the heater doesn't HEAT the water it's just a vehicle for the heat via the heater core which is a mini radiator which radiates heat into the cab. You adjust the heat via a cable which limits or shuts off the hot water coming from the heated water in the engines internal water jackets. You'll get your heat... oh wait a minute.. I think I know what you're talking about....what if you DON'T HAVE THE HEATER ON... IS THE WATER STILL GOING TO CIRCULATE?
I think most people run a separate heating loop which is what I have planned for my Edelbrock conversion.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | The heater doesn't heat the water? That's stupid... when did they change that... how an I supposed to make tea and Ramen noodles with cold water?  | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | It depends on which heater you have. The deluxe heater has a flow control valve which would limit the amount of water heat into the intake. The non-recirc heater does not come with a valve.
However, you are likely to have the cabin heat on when you need manifold heat anyway, so its not too likely to be a problem.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Thanks everyone. I'm getting a thing that adds a hose fitting and I'll simply add a T to the return line so that water circulates continuously.
Thanks to everyone for clearing this up for me. | | | | | Joined: Jan 2001 Posts: 1,422 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,422 | Fantastic water heated plumbing is shown here. This is one of the cleaner applications I have seen. I actually went w/o a heated manifold for about a month and a half this past summer and the truck performed poorly. I made my own bottom plate similar to this. Here's water heated loop terminus.
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I don't want to hi-jack this thread "but", I have a question. Who supplies the double t clamp shown in cosmos picture.I'm referring to the clamp holding the two water lines apart.I can find the plastic ones,but no luck finding the metal ones.
Thanks !!!!!!!!!!! 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | Thanks for the compliment on my system Cosmo! The idea actually came from 4onthefloor(thanks again). You don't need the "T" if you utilize a bypass thermo housing and a waterpump from a 261 as 4onthefloor suggested. The waterpump that NAPA sells for the 235 is the same as the original 261 pumps. They have the dual fitting holes and will work. The thermo housing from a 261 may take some time to find. An option to that is the fitting plate that Tom Langdon sells that goes between the therm-housing and the head. It is good because the fitting comes out on the drivers side so the tube bending will be cleaner and easier. The heatplate started out as a 4"X5" piece of 5/16" flatbar. I cut it to size with a hacksaw, then shaped it with a grinding wheel. The lines are cheap brake lines from NAPA. The fittings took a while to gather and get right, but then all you need is a cheap tubing bender and a flaring kit and your off to the races. It helps to have a neighbor with a machine shop who can drill and tap the inlet/outlet holes in the plate! The moral of the story is you don't have to be a mechanic to do it. | | | | | Joined: Apr 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 275 | Bow Tie - Go to summitracing.com & do a search for line clamps. Doug | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | ''' I'm referring to the clamp holding the two water lines apart. '''
that's a common hot rod fuel ''bullet type'' clamp search any or go to a rod shop. they are available in many and different sizes, same-same, or large/small
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | desertdog and carolines truck, I was talking about the clamps holding the water line apart.I can find the plastic ones in the right size.I can't find the metal ones in the right size.I checked summit,they don't have them in the sizes i need.
I'll do some more checking,thanks !!!!!!!!! 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Apr 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 275 | | | |
