7 members (BC59, David Bush, MikeE, Bucker, MickeyP, Rexville48, dt235sd), 83 guests, and 1 robot.
Topics128,049
Posts1,055,702
#3563 07/29/2004 2:07 AM
Can anyone tell me how to repair the push button lights on the radio of my 96 silverado? I took the front off but didn't see anything to replace.
No hill for a climber!
#3564 07/30/2004 2:07 AM
Hi, ole lonely,
I don't know if my memory serves me will or not, but on the old radios (I assume that you are using an old one) the dial light was in a socket that snaps on the top near the front. I'm not sure of the set-up in your vehicle but it may be possible to access it through the ash tray or maybe you can reach around and on top. Then, it might be that you will have to take it out. That's the best I can help with my memory. Its been a long time.
Truck Tinker
#3565 07/30/2004 2:20 AM
Sorry, I didn't notice the year model when I first read your post. I just went out and looked at my 91 out of curousity and I couldn't get my hand anywhere near the radio. Maybe if you took off the panel under the sector, you can reach the socket wherever it is. Best ask a service man at the dealer.
Truck Tinker
#3566 07/30/2004 2:40 AM
Maybe he's got an AD radio in his Silverado. grin grin
#3567 07/30/2004 3:35 AM
The numbers on the push buttons should lightup but i dont see any lamps to replace. I tried once, took the front cover off and only managed to burn out a couple more. It's all agreat mistery.
