6 members (fonz8261, Barry Martak, 55shaker, TUTS 59, LAJones48, Dusty53), 142 guests, and 2 robots.
Topics128,088
Posts1,056,416
Members48,443
just made my purchase on a '49 gmc d-lux cab and have not been able to take possession of it yet.(weather!) the one thing i do need first of all is to order me a electric fan kit..w/ all the necessary's(mounting kit,thermostat)just need to get an idea of what the "across" diameter,and the "height" is so i can go ahead and order one.the p.o. said that the original radiator had been gone through and checked and that the shop that had performed the rad. service told him that the rad. had a 5 row......? is this true for these years of trucks? any information is greatly appreciated on this subject. :confused:
'68 chevy shrtbd fleetsde 350/350 edelbrock total performance power pkg.(carb,intake,cam,lifters,dbl roller timing chain)lowered 3"frt. 4"rr.totally restored w/ new tweed interior.AND 6 LUG DRUM BRAKES ALL 'ROUND! new family member: '49 gmc 1/2 ton shrtbd.d-lux cab,power disc brakes,(monte carlo sub frame)red oak wood bed w/ s/s stringers,'65 chevelle rearend,15x8 ralley's on b.f. goodrich radial t/a's 4"beauty rings and derby cap's. '86 3/4 ton lngbd.454/400th,parts fetcher and daily driver.
rat Offline
Doesn't sound like the original radiator to me. I heard of them being 4 core but not a 5. What engine is in the truck?
'52 Chevy 5 window, it ran when I parked it
'53 Chevy 5 window, running the streets with me.
'55 Massey-Ferguson, tearing up the dirt
'89 Harley FXSTS, suicide clutch
'92 Harley FLSTC, equal time with the '89
the engine in it now is a 355ci sb...., and he was adamant that the radiator was a 5 row. he pointed to the center of the radiator and said that the very center of the radiator had 5 rows. i'm gonna need to get him to clarify the radiator issue.as for the width and height .....? the dimensions are still needed... as the core support area and surrounding sheetmetal is all stock.
I am using a 19" fan on my Chevy, and there is plenty of space under there for a bigger one.
Paint & Body Shop moderator
Z
Z Offline
When installing a 350 sb the fan sits mighty low, I removed mounting tabs off radiator lowered and moved forward to clear steel blade and made custom fan shroud. I added Vintage a/c condensor and transmission oil cooler, making electric fan mounting tough. See if this link works my first time trying with photo's
http://community.webshots.com/user/zeker6[/URL]
Zeke
The Amish Connection
51 Chevy 1/2 ton 5 window,Vortec hotrod, no horse
thanks for the replies! 19" is a pretty good size diameter to be running...had any problems w/ engine temp.? and did you mount from inside (pulling) or from the outside (pushing)?
I have a 350 sbc in my 54 and we just put a new Walker Z-Cool radiator in ... same problem; the fan was sitting way too low. So we removed the fan and installed a 16" electric fan w/shroud.
Perfecto! And I can't hear the fan at all -- note: we wired the fan through the ignition so it doesn't keep running when I turn the engine off,
You can Check It Out Here.
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
zeker6,
Can't open your webshot site.
Craig
thanks for the info horvath!i'll be ordering a new fan and shroud very soon. wouldn't happen to have the part #'s on the fan and shroud would you? and did you order the fan and shroud through summit racing equipment? thanks.... grin
Z
Z Offline
I stink I fixed it! Zeke
I run the fan on the outside of the radiator with a thermostatic switch. It is a 2400 CFM fan, and it keeps the 261 cool in the local weather, which rarely hits 95 in the summer. For a 350 I would get a higher CFM fan, in the 3000 range. I put it in mainly for clearance reasons.
Hey, buxman66
I don't know the part numbers -- my mechanic ordered everything. The shroud was ordered with the Walker radiator ... he ordered the 16-inch electric fan locally. What I do know, is the fan has "S" shaped blades -- he said those are the quietest ... and he was right -- I never hear it!
~~ Alan Horvath
1954 Chevy Pickup
Passing Lane
thanks again everybody!! all you're guy's pics really help... smile
