| | | Forums66 Topics128,088 Posts1,056,413 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#35610 03/17/2004 9:26 AM | Joined: Mar 2004 Posts: 12 Member | | Member Joined: Mar 2004 Posts: 12 | just made my purchase on a '49 gmc d-lux cab and have not been able to take possession of it yet.(weather!) the one thing i do need first of all is to order me a electric fan kit..w/ all the necessary's(mounting kit,thermostat)just need to get an idea of what the "across" diameter,and the "height" is so i can go ahead and order one.the p.o. said that the original radiator had been gone through and checked and that the shop that had performed the rad. service told him that the rad. had a 5 row......? is this true for these years of trucks? any information is greatly appreciated on this subject. :confused:
'68 chevy shrtbd fleetsde 350/350 edelbrock total performance power pkg.(carb,intake,cam,lifters,dbl roller timing chain)lowered 3"frt. 4"rr.totally restored w/ new tweed interior.AND 6 LUG DRUM BRAKES ALL 'ROUND! new family member: '49 gmc 1/2 ton shrtbd.d-lux cab,power disc brakes,(monte carlo sub frame)red oak wood bed w/ s/s stringers,'65 chevelle rearend,15x8 ralley's on b.f. goodrich radial t/a's 4"beauty rings and derby cap's. '86 3/4 ton lngbd.454/400th,parts fetcher and daily driver.
#35611 03/17/2004 2:01 PM | Joined: Feb 2000 Posts: 50 Member | | Member Joined: Feb 2000 Posts: 50 | Doesn't sound like the original radiator to me. I heard of them being 4 core but not a 5. What engine is in the truck?
'52 Chevy 5 window, it ran when I parked it '53 Chevy 5 window, running the streets with me. '55 Massey-Ferguson, tearing up the dirt '89 Harley FXSTS, suicide clutch '92 Harley FLSTC, equal time with the '89
#35612 03/17/2004 6:27 PM | Joined: Mar 2004 Posts: 12 Member | | Member Joined: Mar 2004 Posts: 12 | the engine in it now is a 355ci sb...., and he was adamant that the radiator was a 5 row. he pointed to the center of the radiator and said that the very center of the radiator had 5 rows. i'm gonna need to get him to clarify the radiator issue.as for the width and height .....? the dimensions are still needed... as the core support area and surrounding sheetmetal is all stock.
#35613 03/17/2004 8:16 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I am using a 19" fan on my Chevy, and there is plenty of space under there for a bigger one.
#35614 03/17/2004 10:24 PM | Joined: Aug 2001 Posts: 154 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2001 Posts: 154 | When installing a 350 sb the fan sits mighty low, I removed mounting tabs off radiator lowered and moved forward to clear steel blade and made custom fan shroud. I added Vintage a/c condensor and transmission oil cooler, making electric fan mounting tough. See if this link works my first time trying with photo's http://community.webshots.com/user/zeker6[/URL] Zeke
The Amish Connection 51 Chevy 1/2 ton 5 window,Vortec hotrod, no horse
#35615 03/18/2004 9:04 AM | Joined: Mar 2004 Posts: 12 Member | | Member Joined: Mar 2004 Posts: 12 | thanks for the replies! 19" is a pretty good size diameter to be running...had any problems w/ engine temp.? and did you mount from inside (pulling) or from the outside (pushing)?
#35616 03/18/2004 10:02 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | I have a 350 sbc in my 54 and we just put a new Walker Z-Cool radiator in ... same problem; the fan was sitting way too low. So we removed the fan and installed a 16" electric fan w/shroud. Perfecto! And I can't hear the fan at all -- note: we wired the fan through the ignition so it doesn't keep running when I turn the engine off, You can Check It Out Here.
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
#35617 03/18/2004 3:37 PM | Joined: Jan 2002 Posts: 2,841 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,841 | zeker6, Can't open your webshot site.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#35618 03/18/2004 6:01 PM | Joined: Mar 2004 Posts: 12 Member | | Member Joined: Mar 2004 Posts: 12 | thanks for the info horvath!i'll be ordering a new fan and shroud very soon. wouldn't happen to have the part #'s on the fan and shroud would you? and did you order the fan and shroud through summit racing equipment? thanks....
#35619 03/18/2004 7:45 PM | Joined: Aug 2001 Posts: 154 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2001 Posts: 154 |
#35620 03/18/2004 8:15 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I run the fan on the outside of the radiator with a thermostatic switch. It is a 2400 CFM fan, and it keeps the 261 cool in the local weather, which rarely hits 95 in the summer. For a 350 I would get a higher CFM fan, in the 3000 range. I put it in mainly for clearance reasons.
#35621 03/18/2004 9:05 PM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Hey, buxman66
I don't know the part numbers -- my mechanic ordered everything. The shroud was ordered with the Walker radiator ... he ordered the 16-inch electric fan locally. What I do know, is the fan has "S" shaped blades -- he said those are the quietest ... and he was right -- I never hear it!
#35622 03/19/2004 7:45 AM | Joined: Mar 2004 Posts: 12 Member | | Member Joined: Mar 2004 Posts: 12 | thanks again everybody!! all you're guy's pics really help...
