0 members (),
79
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 338 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 338 | I have a new starter for my engine. I was wondering if I just bolt it up to the engine or do I grease it up a little. I have done this before and for the life or me, I can't remember putting anything on the starter gear, but it seems like something I should do. I guess I'm asking what everyone else does. Thanks. Oh sorry for the title.  | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I have changed a few in my time but never recall lubricating anything. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | no grease anywhere near the flywheel/clutch for me thanks
Bill | | | | | Joined: Jul 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 461 | You can use a little white grease (lithium grease) on the gear if you want to, but usually they don't get any lubricant. The drive clutch will usually wear out before the drive gear or ring gear shows any wear.
Harvester | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Hi Bill - Happy New Year to you and everyone else! I'm with red58! I have had experience with oil and /or grease on the flywheel and clutch. I would not get any oil or grease close to the flywheel. Life will be much easier without the oil or grease!! Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 |
Bill Burmeister | | | | | Joined: Feb 2005 Posts: 338 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 338 | Joe,
And others. Happy New Year.
Sounds like no oil/grease is the way to go.
Thanks, | | |
