| | | Forums66 Topics128,143 Posts1,056,786 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 29 | I have a ooold drop axel with 5 lug drums,i dont know what they are off looks to be "bolt on" cant see any #s any sugestions? Will 55-59 axel interchange 47-54 1/2tons? | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | No. The springs on the 47-54 run kinda tow in... that is they mount closer together in the front, and further apart in the back. The springs are parallel on the 55-59. I believe tha backing plates and the hubs will switch over from those years, but the I beams themselves are a no-go. | | | | | Joined: Sep 2007 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 29 | Center 2 center spring pack bolt not same? I also need to I.D. the hubs and drums maybe 50s car steel drums so not buick? any idea ? | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | You could measure the bolt pattern to get a better idea what they might be... Also the inside diameter of the brake drums would help.
And pictures.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Sep 2007 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 29 | Bolt pattern 5 on 4 3/4 drums look to be 11 1/2 id x 2?? been it weather 5 year at least now im trying to get off drums try to loan a drum puller il take pics tonight i have to read how to post pics???? thanks for help | | | | | Joined: Nov 2003 Posts: 70 New Guy | | New Guy Joined: Nov 2003 Posts: 70 | You've probably got 49-54 car hubs and drums on your axle. If they're the original drums they will be riveted to the hub with 3 big rivets so look close before you use a puller. If they're not the original drums you'll still see the ground off rivets on the hubs. I've got this setup on my 31 pickup with 52 car wheels. It's a cheap way to get 5x43/4 bolt pattern. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I agree, 5x4.75 sure sounds like Chevy car stuff from those years.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Sep 2007 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 29 | raining cant check for rivits or get pics tonight but il post asap thanks for help | | |
