2 members (dt235sd, Sjm),
99
Mod | | | Forums66 Topics128,283 Posts1,058,505 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,558 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,558 | I would like recomendations for manifolds and carb for a gmc 270 to be installed in my 41 1/2 ton with stardard drive line. I just got the engine, it has no manifolds or carb right now. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | I had a '39 with a GMC 270 engine, had the Howard 5 carb. manifold, really has a big WOW factor, also really wakes it up. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Clifford 4-barrel manifold with heat and a 390 cfm carb. The most economical option, easy to tune and maintain, with more go when you need it. It's uniqueness gives it sex appeal at the curb too. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | If you are looking for more of a stock appearance than the 2bbl manifold from a 302 will work as well- the early ones fit the 3-bolt Stromberg/Holley pattern, and the later ones fit the 4-bolt GM Rochester 2GC pattern.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Sep 2007 Posts: 6 New Guy | | New Guy Joined: Sep 2007 Posts: 6 | Good suggestions all fellas! Patrick's also has a 4bbl intake for '270 and '302 gmc engines and 390 carb is perfect! We have had great success with this combination and Fenton Headers! which also look beautiful with the Jet Hot coating! The gmc engines run really strong with the 4bbl altho the 5 carb looks more nostalgic.whichever way you go,I hope you have a cam to handle the extra carburetion? I would recommend around a 264 or an F290 grind for you. thanks,phillip | | |
