5 members (Jon G, Wayne67vert, Jaison, Hotrod Lincoln, fonz8261), 131 guests, and 2 robots.
Topics128,162
Posts1,056,960
Members48,458
I would like recomendations for manifolds and carb for a gmc 270 to be installed in my 41 1/2 ton with stardard drive line. I just got the engine, it has no manifolds or carb right now. Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
I had a '39 with a GMC 270 engine, had the Howard 5 carb. manifold, really has a big WOW factor, also really wakes it up.
Clifford 4-barrel manifold with heat and a 390 cfm carb. The most economical option, easy to tune and maintain, with more go when you need it. It's uniqueness gives it sex appeal at the curb too.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
If you are looking for more of a stock appearance than the 2bbl manifold from a 302 will work as well- the early ones fit the 3-bolt Stromberg/Holley pattern, and the later ones fit the 4-bolt GM Rochester 2GC pattern.
Paint & Body Shop moderator
Good suggestions all fellas! Patrick's also has a 4bbl intake for '270 and '302 gmc engines and 390 carb is perfect! We have had great success with this combination and Fenton Headers! which also look beautiful with the Jet Hot coating! The gmc engines run really strong with the 4bbl altho the 5 carb looks more nostalgic.whichever way you go,I hope you have a cam to handle the extra carburetion? I would recommend around a 264 or an F290 grind for you. thanks,phillip
