0 members (),
38
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#35366 07/15/2003 3:05 PM | Joined: May 2002 Posts: 14 Apprentice | | Apprentice Joined: May 2002 Posts: 14 | I have a '49 1/2-ton with a 3-speed transmission. It leaks like crazy when either in reverse or idle. Otherwise, no leak. You can see the streak start where I put it in idle down the driveway or when backing into the garage. Someome mentioned the idler gear, which makes some sense, but I am not sure why that would cause a leak. I see the "stream" coming out of the hole in the cover over the flywheel. Honestly not even sure whether it is leaking gear oil from the tranny or engine oil. I did have the rear main seal replaced a while back.
Any ideas?
Greg - 49 1/2 ton
#35367 07/15/2003 5:45 PM | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | I have a hunch that it is going to be the rear main seal that is your problem. Doesn't make much sense to be the tranny. If it is your rear main seal try this tech tip- tech tip Be sure to get the wick type seal with asbestos in it. Seals a lot better. Do it yourself- it is really easy to do. Then you know it is done correctly.
Oly in Oregon Rest in Peace1945 GMC COE Victory Truck 1953 Willys CJ3B 1955 Chevy 1st series 3/4-ton 1958 WIFE Last series Never say "Whoa" in a mud hole
#35368 07/15/2003 6:21 PM | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | Is it possable that you have too much oil in the truck??? | | |
#35369 07/15/2003 8:09 PM | Joined: May 2002 Posts: 14 Apprentice | | Apprentice Joined: May 2002 Posts: 14 | Well... too much oil did cross my mind, because in spite of the leak, it is still showing full each time I check it. Would this kind of leak be a symptom of too much oil, though?
Greg - 49 1/2 ton
#35370 07/15/2003 8:59 PM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | How about a smell test ? I also am investigating a possible leaky tranny issue. To me tranny oil smells much different than engine oil. What I've seen on the ground smells just like tranny oil.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#35371 07/15/2003 9:51 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | An overfilled tranny will barf oil.
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#35372 07/16/2003 12:32 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Have you checked the oil level in the tranny? there is suppose to be either a shield/slinger or a felt type seal in the front nose-cone of the tranny. Some have a helical cut groove in the tranny input shaft which when it is turning will sort of force the oil back toward the inside of the tranny. Tranny gear oil will be a lot thicker and smell pretty bad as compared to the engine oil. If you are not losing any engine oil, I would definitely inspect the tranny.
