1 members (TooMany2count), 120 guests, and 3 robots.
Topics128,193
Posts1,057,257
Members48,466
Fox
Offline
Hi! I'm new to the whole resto/custom truck world, and I have some questions regarding my '50 3100. Has anyone tried to put a S-10 rearend and suspension in an Advance Design? Any replies would be greatly appreciated. Thanks.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Welcome to the Stovebolt page ...
... Advanced Design body on S10 runnin'gear, they do that, but seems I usually see folks try to use the whole chassis from the long wheel base S-truck, though I am not necessarily advocating that. Are you planning to retain the original front end? What transmission?
To browse and find earlier discussions, go back to previous page and see that pull-down box at upper right, "Show topics from last (# of) days," and also look in "the lounge."
Best of luck.
Ed B.
Fox
Offline
Thanks Ed B.
I am thinking of using a Mustang II frontend with a 350/400 combo. I will most likely have to get a driveshaft made.
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Somebody on the Stovebolt site was talking about this in recent weeks and shared this link:
www.usbodysource.com/Install%2047%20chevy.htm
If you're set on the S-10 diff, in 1989 they started using a bigger unit, 7.625" if I recall. They weren't on all '89s, just started appearing then. They're not easy to tell apart from the 7.5" just by looking at the cover. You'll need a maximum of 4" backspacing on your rims to make the tires clear your bed.
I've heard a '72-ish Nova/Apollo rear axle is pretty much a bolt-in. I would bet that's a beefier unit, and available in a number of gear ratios. Get the speedo gear from the donor vehicle while you're at it, it might help down the road. '89 S-10s used an electric speedo so the "gear ratio" is stored in the ECM.
Shop rates at a nearby garage:
$50/hr
$75/hr if you watch
$100/hr if you help
Fox I have an 88 Blazer rearend in my 38 and I think the dimensions are the same. It's the smaller Blazer not the full size. For the frontend I would suggest having a look here it is in Canada and close to you so you can probably save a few bucks on the exchange etc.
www.macgyvers.com
I am going to get some pictures onto my site soon of the retrofit. I have the whole frame boxed in front to back as some metal gets a bit thin after 64 years.
LOL
John....38 Chevrolet Panel Delivery
http://community.webshots.com/user/tobytailford
Fox
Offline
Thanks everyone.
John, I am most likely going to go with a macguyer's frontend. I've been on their site before. I hope my S-10 rearend works. Thanks again.
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
