7 members (Samantha, cmayna, 55shaker, Bill Hanlon, TooMany2count, 1955 1 Series, Otto Skorzeny),
102
Mod | | | Forums66 Topics128,071 Posts1,055,901 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#35323 01/07/2002 11:32 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Should I use iron or moly rings in my .060 over 235? I ordered a master rebuild kit from Patrick's, and it comes with iron rings. I'm going to use cast flattop pistons, shaved head, cam, 4 bbl, fentons, HEI.
Thanks Chiphead
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#35324 01/08/2002 1:57 AM | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I used moly in my 235. They take a bit longer to get seated than cast iron, but wear longer.  | | |
#35325 01/08/2002 3:01 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Are all 235 piston rings the same width? Can either iron or moly rings be used on the same piston? Do moly rings require a special hone on the cylinder walls?
Thanks again Chip
#35326 01/08/2002 4:22 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | the rings should be the same for the piston.I believe the cross-hatch(scratch marks made from honing are suppose to be at a different angle for each type of ring.45*angle for the cast iron ring and I cannot recall off the bottom of my head  which angle is used for the moly rings.Someone here will probably answer befor I remember!
#35327 01/09/2002 4:16 PM | Joined: Apr 2001 Posts: 39 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 39 | chip if you would give me a call .i have misplaced your ##.924.4489 thanks BOBBY
47 Chevy COE..52 TO 30
