6 members (50Chevy3100, Shardean, Lostbuthaulinass, Peggy M, Joe H, 1 invisible), 91 guests, and 2 robots.
Topics128,057
Posts1,055,815
#35323 01/07/2002 11:32 PM
Should I use iron or moly rings in my .060 over 235? I ordered a master rebuild kit from Patrick's, and it comes with iron rings. I'm going to use cast flattop pistons, shaved head, cam, 4 bbl, fentons, HEI.
Chiphead
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#35324 01/08/2002 1:57 AM
I used moly in my 235. They take a bit longer to get seated than cast iron, but wear longer. smile
#35325 01/08/2002 3:01 PM
Are all 235 piston rings the same width? Can either iron or moly rings be used on the same piston? Do moly rings require a special hone on the cylinder walls?
Thanks again
Chip
#35326 01/08/2002 4:22 PM
the rings should be the same for the piston.I believe the cross-hatch(scratch marks made from honing are suppose to be at a different angle for each type of ring.45*angle for the cast iron ring and I cannot recall off the bottom of my head grin which angle is used for the moly rings.Someone here will probably answer befor I remember! eek
#35327 01/09/2002 4:16 PM
chip if you would give me a call .i have misplaced your ##.924.4489 thanks BOBBY grin
47 Chevy COE..52 TO 30
