| | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2 Junior Member | | Junior Member Joined: Jan 2002 Posts: 2 | My '54 235 has come back to life after sleeping in a field for 1-year. I have replaced all ignition parts, cleaned the carb. It appears to be the stock 1-bbl Rochester carb. I am having trouble getting the truck to idle. Can anyone tell me: > How many turns should I run-out the mixture screw at the base of the carb? > How do I adjust the idle speed when I have the mixture correct? > The truck doesn't seem to want to start without a shot of starting fluid. What does this mean?
IT'S ALIVE!!
Thanks for your help. | | | | | Joined: Jan 2001 Posts: 14 Member | | Member Joined: Jan 2001 Posts: 14 | I turned mine out 2 turns as a starting point, idle speed is then adjusted with a screw on the throttle linkage on the drivers side of the carb toward the firewall. I also noticed that the timing made a big difference in the idle speed. there are several threads about carb adjustment here if you use the search function. what part of indiana are you located in, I am in Fishers In. Rog | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | How did you adjust your points? It's tough to get them right with a feeler gauge unless you have a lot of practice. If you can locate a dwell meter, you can be far more accurate.
Fred 52 3600 69 C-10
| | | | | Joined: Jan 2002 Posts: 72 Member | | Member Joined: Jan 2002 Posts: 72 | khacker, in regard to the hard start! as I found out thru this forum, be sure to check that the choke is functioning...that was the key to my easy starting.
49' Chev, 3808 platform
