1 members (1 invisible),
105
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#35142 05/06/2003 12:35 PM | Joined: Mar 2003 Posts: 313 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 313 | I have redone the Brake system on my 1936 GMC 1/2 ton. Everything has been replace with the exception of the brake lines. I have bleed the brakes three times and I still cannot get any pedal pressure. If I pump the master cylinder three or four times, I finally get some pressure. Help!, its driving me crazy! | | |
#35143 05/06/2003 1:18 PM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | If you can pump them a few times and come up with a pedal, that is usually an indication that they are out of adjustment.
Try adjusting the brakes and let us know what happens..
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#35144 05/06/2003 10:34 PM | Joined: Mar 2003 Posts: 313 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 313 | Thanks, Bill,works like a champ! I also talked to an old crusty guy in St.Petersburg who had owned five of these trucks (Chevy and GMC). He told me to adjust each side of the wheel cylinder so that the wheel is locked up and back off until there is about "a five pound bag of sugar" of drag on the wheel. He said that it will go away after about 4 to 5 miles. I appreciate your help! Thanks! | | |
#35145 05/07/2003 8:17 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Does that put Bill in the "old crusty guy" category? Finally found something else to call him.
Fred 52 3600 69 C-10
#35146 05/07/2003 8:50 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 |
