3 members (Wheelie, Ole49GMC, GMCJammer51), 98 guests, and 3 robots.
Topics128,030
Posts1,055,430
Members48,422
#35142 05/06/2003 12:35 PM
D Online: Content
I have redone the Brake system on my 1936 GMC 1/2 ton. Everything has been replace with the exception of the brake lines. I have bleed the brakes three times and I still cannot get any pedal pressure. If I pump the master cylinder three or four times, I finally get some pressure. Help!, its driving me crazy!
1936 GMC T-14 1/2-Ton Pickup
#35143 05/06/2003 1:18 PM
If you can pump them a few times and come up with a pedal, that is usually an indication that they are out of adjustment.
Try adjusting the brakes and let us know what happens..
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#35144 05/06/2003 10:34 PM
D Online: Content
Thanks, Bill,works like a champ! I also talked to an old crusty guy in St.Petersburg who had owned five of these trucks (Chevy and GMC). He told me to adjust each side of the wheel cylinder so that the wheel is locked up and back off until there is about "a five pound bag of sugar" of drag on the wheel. He said that it will go away after about 4 to 5 miles. I appreciate your help! Thanks!
#35145 05/07/2003 8:17 PM
Does that put Bill in the "old crusty guy" category? Finally found something else to call him. grin
Fred
52 3600
69 C-10
#35146 05/07/2003 8:50 PM
grin
