0 members (), 347 guests, and 1 robot.
Topics128,101
Posts1,056,180
Members48,436
#350993 12/21/2007 4:39 AM
I'm not quite sure what to make of THIS
It looks like an oiler that's been pinched off and I'm not quite sure why. This is a recently rebuilt engine that I'm partially disassembling so I can have my mechanic look at it before the warranty expires.
Someone told me this was done because too much oil was getting to the rockers, taking oil from other areas... sounds odd to me.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
The pinching off of that tube was done to force more oil through and toward each end of the rocker arm shafts where the oil is needed.
Well sorry for the delay Woody, it take close to an hour to take a picture, edit and upload it to Webshots with my dial-up connection.
Your probably aware of this but it might help one of the new guys. The clip on top of the oiler is a deflector, under the clip is a metering hole drilled in the top of the tube. The access oil is dumped back into the block through the drain hole in the head. http://rides.webshots.com/photo/2422488820098611668kKpgfp
Your oiler probably got broken off and they squeezed it shut to try and meter the flow. If it were me, I would install a new oiler.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Ex Hall Monitor
Ex Hall Monitor
The normal hole in the end of the oiler is to allow excess oil to escape when the rocker shafts are full. It looks to me like someone's attempt to increase the oil pressure to the rockers by restricting the overflow. Will it hurt anything? Probably not. The rocker oiling system isn't tight enough to hold high pressure anyway.
Is anyone sure that the pinch in the oiler was never done in the factory?
Tim
Ex Hall Monitor
Ex Hall Monitor
Tim
Only by association Tim. My original and the extra replacement I bought off of eBay just to have as a spare aren't crimped.
Tiny,
I have also bought NOS oilers and they are also not pinched. This spring, a friend of mine will be installing a 261 that has never been installed in a vehicle. We'll be taking off the valve cover and I'll check the oiler.
Who knows, they might have pinched the rocker-arm oiler at the factory (maybe when testing the engine, after warm-up, to bring the oil pressure up to "factory specs". wink ohwell
Tim
Ex Hall Monitor
Ex Hall Monitor
Like you say, who knows. They wouldn't gain much though because the fitting is held in place between the rocker shafts with just spring pressure. It wouldn't take much in the way of oil pressure to leak past the connection. :hammering:
