1 members (FishinToms53), 74 guests, and 3 robots.
Topics128,030
Posts1,055,428
Members48,422
#351011 12/21/2007 5:22 AM
I am wanting to convert a small rear window to a big rear window on my 64. Is there a template or anything that shows what to cut, where to crimp or flange, to let it accept the new glass? Any help will be appreciated...
Keep on Cruisin'
Lyall
Lyall
Gulfport, MS
1964 Chevy C-10 SWB Stepside
Y
Y Offline
Lyall, I don't know about a template, but Custom Classic trucks had an article for grafting the big window opening. I'll see if I can find my issue and let you know. I don't think it as simple as cutting out the opening for the bigger glass. Found it, July 06 issue, but its for the 55-59 truck. You can check it out on thier web site. I'm not that fimilar with the 60's window, but someother bolter will fill in the blanks.
Yes you can do it. It is not easy by any means. And there are many ways so I guess I am not much help. Except that to tell you that I changed the hole rear panel on My 61. And even at that it is a lot of work. Well it will be when I finish. smile
V
V Offline
It would be a lot easier to change out the cabs. I have two parts trucks w/ big window and thought about it, but I prefer the small window in my 66. To replace cab it's a bolt on process. To do just the window it's alot of cutting and welding x2. From the doner to the project.
1966 C10 250/3 Stepside
1966 C10 327/3 Fleetside
1972 Buick Centurion 455/TH400
1964 Plymouth Valiant 360/A833 4spd
1964 Plymouth Sport Fury 440/727
I've got a new car....It was made in '72
Hey guys! I will check into your suggestions, as this is my first build. I guess buying some really good mirrors is the next option...
Thanks!!
Lyall
Gulfport, MS
