6 members (Shade Baby, 46 Texaco, cmayna, baldeagle, Peggy M, 1 invisible), 77 guests, and 7 robots.
Topics128,018
Posts1,055,342
Members48,419
#350977 12/21/2007 4:02 AM
I'm looking into purchasing a replacement radiator for my 59 1/2 ton Napco. I had my original tested, cleaned and painted and it's in good shape except for a few dents on top. I hate to spend alot of time and money having the body look great but when you open the hood you see those dents. Does anyone have a recommended vendor that they have had success with. I want to make sure it looks and fits like the original.
BrianM
How about NAPA or some other FLAPS?
Or if you're running a big block V8 you might want something that will, for sure, keep your cool? http://www.walkerradiatorworks.com/
~Jim
I've had the top tank taken off before and pounded out. Usually done while they are rebuilding the radiator. It's little things like that which make a good restoration a great one. grin
My Trucks
Stuff I Collect
Here is a trick that has worked before. Your radiator shop has the equipment to seal your radiator and pressure test it. Take a rawhide or other "soft" hammer and rap the dent. Some times it will spring right back out. Good luck.
cgresham1212
If you don't drive it, why have it?
55 1st Series 3100 5 window
Try the above, but with pressure (from a radiator tester)on the tank. IMHO,I would not replace the radiator if it is in good condition, except for the dents.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
I agree with the comments above regarding pressurization. When testing I think they run the radiators up to around 25-30lbs. The metal on them is pretty thin so its possible that the pressure alone will pop out the dents. If not, the gentle rapping should get most of them out.
