0 members (),
118
Mod | | | Forums66 Topics128,186 Posts1,057,320 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 122 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 122 | I'm looking into purchasing a replacement radiator for my 59 1/2 ton Napco. I had my original tested, cleaned and painted and it's in good shape except for a few dents on top. I hate to spend alot of time and money having the body look great but when you open the hood you see those dents. Does anyone have a recommended vendor that they have had success with. I want to make sure it looks and fits like the original. Thanks, BrianM | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | How about NAPA or some other FLAPS? Or if you're running a big block V8 you might want something that will, for sure, keep your cool? http://www.walkerradiatorworks.com/
~Jim
| | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | I've had the top tank taken off before and pounded out. Usually done while they are rebuilding the radiator. It's little things like that which make a good restoration a great one.  | | | | | Joined: Nov 2004 Posts: 117 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 117 | Here is a trick that has worked before. Your radiator shop has the equipment to seal your radiator and pressure test it. Take a rawhide or other "soft" hammer and rap the dent. Some times it will spring right back out. Good luck.
cgresham1212 If you don't drive it, why have it? 55 1st Series 3100 5 window
| | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Try the above, but with pressure (from a radiator tester)on the tank. IMHO,I would not replace the radiator if it is in good condition, except for the dents.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | I agree with the comments above regarding pressurization. When testing I think they run the radiators up to around 25-30lbs. The metal on them is pretty thin so its possible that the pressure alone will pop out the dents. If not, the gentle rapping should get most of them out. | | |
