3 members (DES57, TUTS 59, 1 invisible),
83
Mod | | | Forums66 Topics128,035 Posts1,055,447 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 9 New Guy | | New Guy Joined: Nov 2007 Posts: 9 | Hello.
I have a 65 c-10 and could use some pointers on how to remove the windshield.
Thanks Matt | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Matt, need more info, do you want to save the glass? Are you going to replace the glass & rubber? Check with you local glass shop, most advise is free. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | C4??????
| | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | Cut the gasket on the inside with a utility knife along the inside of the pinchweld. The gasket should be replaced regardless. Then carefully and evenly push the glass out. Helps to have 2 people push. When having it installed again, don't use a corperate glass shop, their hacks. Us a family owned independent shop. I can't stress that enough. | | | | | Joined: Nov 2007 Posts: 9 New Guy | | New Guy Joined: Nov 2007 Posts: 9 | Yes I do plan on keeping the glass. I want to remove all the rust that has built up behind the rubber.
Thanks Wilbur
Matt | | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | Make sure that you do not try to pry it out with anything, they chip really easy, even if you just have a little left in the corner to get out don't force it.. I did on the 64 that a guy wanted its now trash. good luck | | |
