6 members (55shaker, Wickedbass, FAST55, rfs56trk, Hotrod Lincoln, Hanks custodian), 57 guests, and 3 robots.
Topics128,065
Posts1,055,868
Members48,428
#350790 12/20/2007 6:42 PM
Hello.
I have a 65 c-10 and could use some pointers on how to remove the windshield.
Thanks Matt
Y
Y Offline
Matt, need more info, do you want to save the glass? Are you going to replace the glass & rubber? Check with you local glass shop, most advise is free.
Ex Hall Monitor
Ex Hall Monitor
C4?????? grin
Cut the gasket on the inside with a utility knife along the inside of the pinchweld. The gasket should be replaced regardless.
Then carefully and evenly push the glass out. Helps to have 2 people push.
When having it installed again, don't use a corperate glass shop, their hacks. Us a family owned independent shop.
I can't stress that enough.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
wilbur #350885 12/21/2007 12:16 AM
Yes I do plan on keeping the glass. I want to remove all the rust that has built up behind the rubber.
Thanks Wilbur
Matt
Make sure that you do not try to pry it out with anything, they chip really easy, even if you just have a little left in the corner to get out don't force it.. I did on the 64 that a guy wanted its now trash. good luck
Drive with Pride. mike j
family pic
