5 members (Stovebolt48, 51sub, Wayne67vert, Otto Skorzeny, 1 invisible), 89 guests, and 2 robots.
Topics128,041
Posts1,055,593
#35087 05/27/2003 4:55 AM
guys i'm new to this maybe someone can help...i have a 52 3800 that somebody transplanted a 235? into & the only#s on the dist boss are F415L... could this be a 261? :confused:
#35088 05/27/2003 1:49 PM
The block casting number is only real way to tell...Good luck
Professional Novice
#35089 05/28/2003 12:37 AM
A '52 big truck could have come with a "Loadmaster" splash-oiled 235. The casting number and date will tell. They should be located just above or slightly under the starter but there are exceptions.
#35090 05/28/2003 4:39 AM
thanx forthe replies frank &wally iguess ive gottado a bit more research into it...it does have 2 very big bolts in place of the 2left front headbolts like somesort of acc was hanging there like a comp. and there almost as high as the rocker cover. accy oil filter has big pipe fittings in&out and due to lack of space to steering box/col was clamped on column upside down!!! dont think itsa splash 235 cause its got a long shaft pump upfront &the rad top support isgone &rad is 2/3 in foward now eek eek eek
#35091 05/28/2003 6:34 AM
Big pipe fittings are a good sign. The only stovebolt that had that from the factory is the 261. A few blocks may have them but from the factory they are 1/2" for full flow oiling, so don't bypass that filter. You need to get the block casting numbers from behind the starter. You can also look for the captain's bars above it. Also look for a short pushrod cover (indicates 235/261) You can also try the head casting numbers.
Paint & Body Shop moderator
#35092 05/28/2003 6:12 PM
josiah thanks for the reply starting to take it apart and remove all the crud & build up one thing is definite under the cake midway between the timing hole & dist. boss, on the oilpan rail are 2 cast bosses approx 1 1/4" long spaced about an inch apart thanks for the tip il get the #s off it any way and let you guys know wink
