0 members (), 120 guests, and 2 robots.
Topics128,193
Posts1,057,259
Members48,466
I’m going through a couple of United Motors 986443 Radios out of early 50's trucks and I'm having quite a time removing the old push buttons. I have one pushed back about almost 1/8” and the bar appears to have barbs that the knob is forced over. I don’t want to bend the push bars, which seems likely if I keep prying on the knob.
Anyone experienced with these?
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
When I did my last radio, I just took a pair of pliers and broke the old push buttons off. Then put the new ones in hot water before you install them.
Well, I think I got her figured out. I’m clamping the button in the vise and the slide just wiggles off. A couple of pics of todays exercise:
http://good-times.webshots.com/photo/2239948840098611668bBsFXT
It works just like a new unit now that it has been completely disassembled, cleaned, lubed and adjusted.
One more to go, but I know how it comes apart now.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Denny,
I usually take a pair of side cutters and nibble away the knobs. That way I don't have to exert too much force on the mechanism. That is a good looking unit. No mice in that one!
1951 1 Ton Completed
It's the "push buttons" that I was asking about Fred, the knobs come off nice and easy but the buttons are pushed on to the barb on the slide. I got her figured out so you can even use the old ones if you can get them cleaned up. There is a picture of how I got the buttons off without damaging either party. I took all ten buttons off and could use them again if I wanted to sand and buff them. http://good-times.webshots.com/photo/2731935820098611668rsWvqP
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Denny, you just save the buttons on my radio. I tried almost everything but destroying them and was going to be replacing with repops. I can now remove them, sand and buff them and should be able to reuse them too.
Glad it work out for you. Once these push button mechinisms are cleaned, lubed and freed up they work real nice and smooth.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
I gently heated mine with a torch, then pulled them off with a pair of pliers.
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics
Moderated by  truckernix
