| | | Forums66 Topics128,185 Posts1,057,203 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I’m going through a couple of United Motors 986443 Radios out of early 50's trucks and I'm having quite a time removing the old push buttons. I have one pushed back about almost 1/8” and the bar appears to have barbs that the knob is forced over. I don’t want to bend the push bars, which seems likely if I keep prying on the knob. Anyone experienced with these? Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Nov 2001 Posts: 1,521 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,521 | When I did my last radio, I just took a pair of pliers and broke the old push buttons off. Then put the new ones in hot water before you install them. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Well, I think I got her figured out. I’m clamping the button in the vise and the slide just wiggles off. A couple of pics of todays exercise: http://good-times.webshots.com/photo/2239948840098611668bBsFXT It works just like a new unit now that it has been completely disassembled, cleaned, lubed and adjusted. One more to go, but I know how it comes apart now. Denny Graham Sandwich, IL
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Denny, I usually take a pair of side cutters and nibble away the knobs. That way I don't have to exert too much force on the mechanism. That is a good looking unit. No mice in that one! | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | It's the "push buttons" that I was asking about Fred, the knobs come off nice and easy but the buttons are pushed on to the barb on the slide. I got her figured out so you can even use the old ones if you can get them cleaned up. There is a picture of how I got the buttons off without damaging either party. I took all ten buttons off and could use them again if I wanted to sand and buff them. http://good-times.webshots.com/photo/2731935820098611668rsWvqP Denny Graham Sandwich, IL
| | | | | Joined: Nov 2009 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 110 | Denny, you just save the buttons on my radio. I tried almost everything but destroying them and was going to be replacing with repops. I can now remove them, sand and buff them and should be able to reuse them too. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Glad it work out for you. Once these push button mechinisms are cleaned, lubed and freed up they work real nice and smooth. Denny Graham Sandwich, IL
| | | | | Joined: Jan 2011 Posts: 152 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 152 | I gently heated mine with a torch, then pulled them off with a pair of pliers.
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics | | |
