7 members (Gdads51, texas46, Otto Skorzeny, TUTS 59, Ponchogl, klhansen, greenie-reddy),
136
Mod | | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#35019 10/23/2003 2:53 AM | Joined: Jul 2003 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2003 Posts: 101 | I bought a 6-bolt 248 flywheel which I believe is off of a 54 1.5 ton. I needed the 6 bolt to fit the crank flange on a GMC 302 which is replacing a 228. I had hoped to use the pressure plate off of a 228 but I see that the 228 has 9 bolts for the pressure plate and the 248 flywheel has 6 bolts that hold on the pressure plate. Is there an easily available pressure plate I can use or do I have to call the junk yard back and buy the 248 pressure plate?
Sidehill, but my friends call me Izzenhood | | |
#35020 10/23/2003 12:40 PM | Joined: Jan 2000 Posts: 206 Member | | Member Joined: Jan 2000 Posts: 206 | The 248 clutch will be your best bet, unless your local clutch shop has a rebuild on the shelf, even then you could use the junkyard clutch as a core. When I went through this a few years ago, there was no other clutch avalable that would work with that bolt pattern and still fit inside the GMC bellhousing. | | |
