4 members (Gdads51, Chris_Welch, texas46, 1 invisible), 144 guests, and 3 robots.
Topics128,267
Posts1,058,386
Members48,485
#35019 10/23/2003 2:53 AM
I
I Offline
I bought a 6-bolt 248 flywheel which I believe is off of a 54 1.5 ton. I needed the 6 bolt to fit the crank flange on a GMC 302 which is replacing a 228. I had hoped to use the pressure plate off of a 228 but I see that the 228 has 9 bolts for the pressure plate and the 248 flywheel has 6 bolts that hold on the pressure plate. Is there an easily available pressure plate I can use or do I have to call the junk yard back and buy the 248 pressure plate?
Sidehill, but my friends call me Izzenhood
#35020 10/23/2003 12:40 PM
The 248 clutch will be your best bet, unless your local clutch shop has a rebuild on the shelf, even then you could use the junkyard clutch as a core. When I went through this a few years ago, there was no other clutch avalable that would work with that bolt pattern and still fit inside the GMC bellhousing.
