2 members (Stewart2, Hanks custodian), 96 guests, and 8 robots.
Topics128,014
Posts1,055,324
Members48,419
#349999 12/18/2007 3:32 AM
were Gmc trucks ever 12 volt positive ground?
1949 SUBURBAN
Not that I'm aware of.
Bill Burmeister
Okay to add to the question what about some of the goofier 12 and 24 volt BIG trucks and military models? I thought GMCs were all positive ground until 1956ish when 12 volt was standardized?
My 1953 Chevrolet
1947.1 Gallery
I don't really know about military trucks or the big trucks, but when the light trucks went to 12 volt ('55 2nd for GMC and Chevy), they went to negative ground, too.
Bill Burmeister
All systems with six volt are positive ground. When the change from six to twelve was made then also the switch was made to negative ground. There may be some military vehicle or the like which may be the exception to the rule.
Way back when ?? the thought was that positive ground six volt systems had better cranking power for starting.
This is true with GMCs but not with most other brands.
Cletis #350189 12/18/2007 11:33 PM
I still thought GMC did 6 volts up until 1956, and Chevy did it until 1955. Anyone have any info on that?
My 1953 Chevrolet
1947.1 Gallery
rustednuts #350200 12/18/2007 11:58 PM
Yes, you are correct for GMC. I think it is also possible for GMC trucks to have 6v positive and/or 12v negative as factory options up to 1957 (and maybe 1958).
There's GMC literature at this website that describes 6v and 12v standard and optional equipment for different sized GMC trucks.
Tim
tclederman #350528 12/19/2007 10:13 PM
Very interesting. Looks like the models that had the 6 volt option were carryover bodies from the '54 model year.
Bill Burmeister
LONGBOX55 #350579 12/20/2007 12:41 AM
Yes, and in 1956, GMC had a factory option 12v to 6v converter to provide power to older 6v trailers.
Tim thanks for the cool source of info!
My 1953 Chevrolet
1947.1 Gallery
