| | | Forums66 Topics128,077 Posts1,056,012 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 17 New Guy | | New Guy Joined: Mar 2005 Posts: 17 | on my 1950 there is a rod that connects the park-brake to a cross bar that pulls the brake cables. The rod is in two parts. It kinda looks to me that there was a short bed rod, and an extention that fit into it, but I'm not sure. At any rate I bought a new rod and it is about ten inches too short, so I am thinking I need another piece (based on the broken piece I took out of there). The truck had some repairs in the past and I am not certain that the parts I took out are really original. Does anyone have some information about the rod(s) that connect from the park brake to the frame-crossing bar that actually pulls the brakes? Did I mention it is a long bed truck?
AusTex | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Take a look at this, night help clear things up. I’m not sure what you mean by long bed, mine is a 1950, 3604 (3/4t) all original. Scroll thru, there are a couple of pics in there: http://rides.webshots.com/photo/2872219070098611668JmjLaJ Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Aus Tex,
I have the same truck as Denny but my rod is presently out of the truck. I restored all the components but have not reinstalled it yet. If this is the style you are looking for reply and I will measure it. One thing you will find when rebuilding or replacing parts is the repro clevis's available are usually shorter so you have to make some adjustments for length. | | | | | Joined: Mar 2005 Posts: 17 New Guy | | New Guy Joined: Mar 2005 Posts: 17 | That is correct piece all right. I bought what I thought was a replacement from Jim Carter parts, but I only got one rod (51 inches long) instead of the two rods joined at that clevis hinge. I don't have the rod that has the T-shaped end (or maybe it's a pin through a hole, my old part is too badly rusted to tell). Did I get the wrong part? http://www.oldchevytrucks.biz/47_55/full.asp?page=86 (Part# MEB299) | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Chances are you got the 3100 series stuff I looked through my Carter catalog but there is no drawing. Let me measure and shoot pictures of all my restored stuff. I will post it tomorrow with a link for you and you can then see what else you may need. Was the spring and wire clip that hold back pedal pressure on your truck? there is an S-clip, a long wire hook and a spring that attaches to the frame. I will shoot pictures of those as well. They attach to the clevis where the two rods come togehter under the truck. I will lay everything out like it goes together on my shop floor and then shoot the pictures for you. I noticed that my 3/4 assembly was significantly different then the 3100 items I saw available. The nice thing is you can fabricate replacements using readily available rods cut to length and the various pieces available form the vendors.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | You can buy threaded rods and clevis from hardware stores; i don't know if the thread will match.
~Jim
| | | | | Joined: Jan 2003 Posts: 48 Apprentice | | Apprentice Joined: Jan 2003 Posts: 48 | I have a 47 long bed, and the pkg brake rod I ordered was also too short. I ended up using threaded rod from the hardware store and spun on two bolts to hold the spring. It works fine and cost a fraction of the too short rod from Carters.
Don't read the directions, that'd be too easy.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Thanks Brad, that helped me as well.
~Jim
