Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Baby53, Pre '68 Dave, cmayna), 166 guests, and 3 robots.
Topics128,282
Posts1,058,497
Members48,490
#3494 07/22/2004 9:14 PM
Hi Guys, I'm sure you have heard this one before but I need advise so here goes. I can't find an original overdrive for my sons 61 1/2 ton pu so I am thinking about using the 5 spd out of an S10 that I found in the local paper for 350 dollars. My question is will this work and whats involved in this swap. Right now the truck has the original three spd. with a hydraulic clutch hung off the right side of the bell housing.What things should I be looking for when I go to this guys house to see the trans. What measuremnts are important to know about, or are there special input shafts needed. Any advise is appreciated and will be put to good use.
Tony
Riding in the Passing Lane
I have never done one but there is a how-to
on the tech tips of this site. Whatch for the
speedo drive. The 88 or 89 up have electric
speedo drive & won,t work unless you have a
custom intrument panel. The price sounds a
little high.
1972 Chevy c10 Cheyenne Super
Y
Y Offline
Tony, I sent you an E-mail. Found an OD tranny for you.
